Tommii Posted May 6, 2021 Report Share Posted May 6, 2021 Hey Ratsun crew, Has anyone put a ka24e wiring harness from a hard body truck on a Ka24e engine from a 240sx? if I get this worked out it’s all going into my 1970 521. Thanx for your help. Quote Link to comment
Lockleaf Posted May 6, 2021 Report Share Posted May 6, 2021 There are a couple of issues to deal with. 1) The truck harness is one complete harness for the whole vehicle, there is not separate engine bay harness. So you will have to extract the engine harness from the full harness. Doable, but slow tedious work. 2) It may require some harness modifications. Things like the throttle body are in different locations between the two versions (intake manifolds are totally different), you may have to extend a few things or possibly even swap the throttle body plug out to match the 240sx. I'm not sure if they match. But yes, you can run the KAE with either harness once all the sensors are hooked up. 1 Quote Link to comment
NukeDuke Posted May 7, 2021 Report Share Posted May 7, 2021 Thanx Lockleaf! Appreciate the info. Quote Link to comment
