VIGIL Posted June 18, 2020 Report Share Posted June 18, 2020 Looking for : 1200 - single crank pulley The plate between the fly wheel & block on the A14 motor Exhaust manifold or header - A14 motor Intake manifold single, dual or stock A14 Carburetor for manifold Rear transmission dust cover oil seal Reverse sensor on transmission for back up lights Slip joint for 5 speed series 60 transmission 18 spline Parts can be new or used in good condition Thanks for your time & help, VIGIL Quote Link to comment
datzenmike Posted June 18, 2020 Report Share Posted June 18, 2020 Try size 14 and Arial font. We're all equal here. If looking for parts start a want add in out classifieds... https://ratsun.net/classifieds/category/9-datsun-parts/ Called an engine plate. Well the B-210s A13 and A14 and the later 210s A12, A14 and A15 all use the same engine plate 30411-H5001. The rear seals are the same for the 56 and 60 series 4 and 5 speeds. 321360-H5000 The 60 series 5 speed reverse light switch is the same as the 210 56 and 60 series 4 and 5 speeds. It's also used in the A10 (HL510) 4 speed Driveshafts for 56 and 60 series 4 and 5 speeds are the same. Automatics a shorter but may have same spline. However aren't 210 driveshaft U joints pressed in and staked??? Quote Link to comment
