Stewart Posted April 28, 2020 Report Share Posted April 28, 2020 Time to replace my 10 yr old tires on my 84 720 Sunrader Camper. Right now I have some Yokohama Y356s 195/75R14s on it front and rear. Can I fit 205/75R14 on it without danger of the duallys rubbing in the rear (Hankook RA18)? Everything else is pretty stock clearance wise (added leaves on the springs to account for sag a few years ago but no lift). Speedometer currently reads a little fast and I wouldn’t mind the extra ~0.7” clearance if I can get it with minimal other handling effects. Thanks! Quote Link to comment
wayno Posted April 28, 2020 Report Share Posted April 28, 2020 You don't want them touching each other in the middle ever, if you can see between them when fully loaded you likely will be fine. 1 Quote Link to comment
