Midri Posted March 1, 2020 Report Share Posted March 1, 2020 So I changed out the fuel sender pump on my injector pump and several ounces of oil came out of the pump... My owners manual is in tatters and my Chilton guide book is of no help here... Can someone explain how I'm supposed to put more oil in and what kind to use? What came out looked like standard diesel engine oil. 1 Quote Link to comment
wayno Posted March 1, 2020 Report Share Posted March 1, 2020 If your talking about the lift pump on the side of the injection pump that has the primer you are fine, engine oil is pumped into the injection pump, I actually don't know how it drains back out, likely thru the gear area on the front of the injection pump. 1 Quote Link to comment
Midri Posted March 1, 2020 Author Report Share Posted March 1, 2020 Yes, that's what I was talking about. Thanks for the info 1 Quote Link to comment
