JASACE Posted November 22, 2008 Report Share Posted November 22, 2008 Ha guys IM from new zealand & i hav a 85 nissan navara dlb cab hb. I am runing the z16 nissan motor. All i hav done to it so far is a lumpe cam grind so now it sounds like a rotary at idol. What i wood like to know is what mods you guys hav done to your z16 0r z18 or z20 motors & other things like what carb wood be best to run & if you guys think porting is any good? Any help wood be good thank. JASACE Quote Link to comment
datzenmike Posted November 22, 2008 Report Share Posted November 22, 2008 (edited) Pictures of that motor!!! All we got were Z20, Z22 and Z24 motors. We've heard of JDM Z18ET motors: http://i138.photobucket.com/albums/q251/datzenmike/motorZ18TETleftside.jpg[/img]"] A cam change is good but the Z head has severe limitations on performance. Power is made in the head and it's design. For power you must have good air flow in and out. (more gas and air = more power) Ideally you want big cam, lots of lift, big valves, big ports and the ability to rev high, so stiff springs and light valve train components. The Z head is limited on how big a valve can be put in, so this leaves opening up the ports and removing casting flash and machine tool marks from installing the valve seats. It has a very sharp short turn radius that can be relieved slightly but never really fixed... again bad design to begin with. I shouldn't say bad design as it was never intended for any performance or high revving and is a good motor for what it does do. Stiffer valve springs will hold the rocker against the cam lobe at higher RPMs and assume you got some with your cam change. Edited November 23, 2008 by datzenmike Quote Link to comment
JASACE Posted November 23, 2008 Author Report Share Posted November 23, 2008 Sweet az ill try get a pix of the motor. Wecan get all them motors here in new zaland to. what carbs do you guys use on your z motors? JASACE Quote Link to comment
datzenmike Posted November 23, 2008 Report Share Posted November 23, 2008 Stock... Hitachi. But there are some after market side drafts. A Z20 or Z22 might be a bit bigger but the Z24 won't bolt onto your manifold. I don't suppose you have a picture of your head used on the Z16? Quote Link to comment
