Garrett_stew Posted September 9, 2019 Report Share Posted September 9, 2019 I have a 1984 Nissan 720 4x4 and there is a rough country lift that is meant for the hard body but can that be used on a 720? Quote Link to comment
datzenmike Posted September 9, 2019 Report Share Posted September 9, 2019 This is a block kit for the leaf springs only? I know the frames are wider apart on the Hardbody than the 720 but if the leaves are just over 2 1/3" wide it may work. Quote Link to comment
Garrett_stew Posted September 9, 2019 Author Report Share Posted September 9, 2019 8 minutes ago, datzenmike said: This is a block kit for the leaf springs only? I know the frames are wider apart on the Hardbody than the 720 but if the leaves are just over 2 1/3" wide it may work. It comes with shocks upper control arms and leaf shackles and I have both kind of trucks and they look almost identical Quote Link to comment
datzenmike Posted September 9, 2019 Report Share Posted September 9, 2019 Extended shackles are no way to lift a vehicle. Does it come with blocks and new U bolts for the springs? Got a picture Quote Link to comment
