Donki Posted June 20, 2019 Report Share Posted June 20, 2019 80 l20b engine I'm at tbc on compression stroke everything is lining up except there's no adjustment room left on distributor even when I loosen up bolt on bottom of dist an top I'm not getting any room for adjustment going 1 way not enough room I need advices 1 Quote Link to comment
Crashtd420 Posted June 20, 2019 Report Share Posted June 20, 2019 Generally that means your off a tooth on the oil pump / distributor shaft..... 1 Quote Link to comment
Crashtd420 Posted June 20, 2019 Report Share Posted June 20, 2019 Pull the distributor and see if it the top of the oil pump spindle looks like this... Quote Link to comment
