Tony22 Posted May 24, 2019 Report Share Posted May 24, 2019 (edited) I have a L20B engine and gearbox from a 910 a (Aussie bluebird ). i want to swap a pintara gearbox into L20B case/ bell housing 910/bluebird gearbox Input 22/31 1.409 ratio 3.321 2.077. 1.308. 1:1 0.838 Pintara gearbox. input 21/33 1.524 ratio 3.592. 2.057 1.361 1:1 0.852 if I keep input shaft and counter gear 1.409 22/31 in 910 bluey case and change too the pintara gearset Change the selector from 14mm to a 16mm selector socket too suit 910 case i hope to end up with input 22/31 1.409 ratio 3.321. 1.901. 1.257 1:1 0.775 ...... 42%. 34%. 20% 22.5% i only have these 2 gearboxes , the bluey 910 box is stuffed but the input and counter gear are good So will this work? not the standard mongrel box I want, but 280zx boxes are hard to find here in OZ and I don't want to spend extra $$$$. This is going in a 521 with a 4.625 diff so the big 1-2 gap 42% give a useable 1st "hard launch" and hold to redline before changing too 2nd :) better to have big gap at lower speed and ratio's closing up from there any thoughts , idea's , comment's ? Recommendations appreciated Tony22 Edited May 24, 2019 by Tony22 Typo Quote Link to comment
datzenmike Posted May 24, 2019 Report Share Posted May 24, 2019 This will depend on the Pintara 1, 2, 3 gear and over drive ratios. Often two boxes are exactly the same but for the input and the counter driven gear. Here's a mid ratio and close ratio zx box gear sets. If you put the zx input set into the mid ratio you get a mongrel box as shown. /. Can you count the first gear ratio and the over drive in the Pinara? These X the 1.4 will give the first and overdrive. There was a '80-'82 zx with a 0.773 over drive. Quote Link to comment
Tony22 Posted May 27, 2019 Author Report Share Posted May 27, 2019 Pintara Ca20 first gear 33/14 = 2.357 X 1.52 = 3.592 Bluey(910) first gear 33/14 = 2.357 X 1.409 = 3.321 pintara Ca20 5th.OD gear. 21/39 = 0.538 X 1.524. = 0.82 OD pintara Ca20 5th OD gear. 21/39 = 0.538 X 1.409. = 0.758 OD :( Bluey(910). 5th OD gear. 22/37 = 0.595 X 1.409. = 0.838 OD :) My 100mph mongrel box swap input from 1.524 with truck #3 / Ca20 > 1.409 should have the following ratio's First. 2nd. 3rd. 4th. 5th OD 3.321. 1.902. 1.258. 1:1. 0.758 OD Or if you can keep bluey (910) OD gears 3.321. 1.902. 1.258. 1:1. 0.838 OD 0.775 OD was typo or bad math 25/28 tooth count for 1.361 3rd gear as pintara box still in car with this box I hope to get close to target under 14 sec 1/4 mile @ 95+mph 4.625 diff, L20B in 521 and a bit of motorkana please advise if I can do this swap ? 5th OD gears swappable? Quote Link to comment
Tony22 Posted May 27, 2019 Author Report Share Posted May 27, 2019 Aussie bluebird is the same a a Maxima L20B the pintara is truck #3 or 83-10/84 200sx with Ca20, ratio % change = 3.321. 42%. 1.901. 34%. 1.258 20% 1:1. OD 0.838. 16% 215/65/14 tyres 4.625 ratio diff speed @6,500rpm= 1, 31mph 2, 55mph 3, 83mph 4th 105mph 5th 125mph Rpm drop 1-2 3721rpm 2-3 4301rpm 3-4 5171rpm 4-5 5447rpm 4.889ratio diff speed @6,500rpm= 1, 30mph 2, 52mph 3, 79mp 4, 99mph . 5. 118mph Rpm drop between gears is the same with any ratio diff now all I need is enough power to achieve it ! ! ! the original 3rd gear 1.36 is a big jump into 4th 27% 6500-4745 swapped input 3rd gear of 1.258 into 4th is 20% 6500-5171 this gear set has a big jump into 2nd although it is 42% that's the same as the standard boxes , a 4.8 Ratio diff will help get off the line Quote Link to comment
