Z20 with a Weber 32/36, vac problems
CharlieMurphy
  • Replies 28
On 12/6/2018 at 8:51 PM, datzenmike said:
If the little pipe is sticking out leave it. Usually a hose goes from it to one of those hard lines down over the front of the engine to near the distributor with a hose to the distributor and the charcoal canister.
It connects to the vacuum advance on the side of the distributor and the charcoal canister. On the canister it only tells it the engine is running and to open the purge valve to remove the fumes but does not take part in it. Just a signal.
