TotalPleb Posted July 8, 2018 Author Report Share Posted July 8, 2018 It does still stall out though, but that might just be because all of the plugs are carbon coated from running rich, as well as the timing still needing adjustment (which I'm going to leave to a professional so I don't mess it up like my other car (the orange one in my profile pic)). Quote Link to comment
nl320what Posted July 9, 2018 Report Share Posted July 9, 2018 When does it stall out, in gear accelerating/reving above 3k rpm/specific scenario? Inquiring minds must know :) Quote Link to comment
TotalPleb Posted July 9, 2018 Author Report Share Posted July 9, 2018 It happen when I went from 2nd to neutral at a stop. I might need to adjust the idle speed. I am having an issue where turning the truck off isn't the end of it and it tries to start itself again. Quote Link to comment
nl320what Posted July 9, 2018 Report Share Posted July 9, 2018 41 minutes ago, TotalPleb said: It happen when I went from 2nd to neutral at a stop. I might need to adjust the idle speed. I am having an issue where turning the truck off isn't the end of it and it tries to start itself again. Crude stuck inside the Idle Cutout Solenoid, or its siezed in. But other things like the timing and internal carb issues will exacerbate this. A Weber is looking better and better. Quote Link to comment
TotalPleb Posted July 9, 2018 Author Report Share Posted July 9, 2018 Where is the solenoid located? Edit: It's the little thing on the carb, right? Quote Link to comment
datzenmike Posted July 10, 2018 Report Share Posted July 10, 2018 There is a filter (ans a magnet) in the base of the electric pump to protect it from crap in the tank. The bottom just twists off. Quote Link to comment
