Datsunny Posted November 5, 2008 Report Share Posted November 5, 2008 what kind of differentials can i put im my 1970 521 Quote Link to comment
datzenmike Posted November 6, 2008 Report Share Posted November 6, 2008 Just the third member or 'bum' without the housing and axles?? Any 521, 620 and 720 2wd. (720 4wd to '82-'83) However there are a wide variety of ratios through these years and a 3.364 is too much of a jump for your L16 or J13. You would want something close to the original. What's the problem with it.?? Quote Link to comment
Datsunny Posted November 6, 2008 Author Report Share Posted November 6, 2008 well i have a guy who has a 260 and was all the parts and i was wondering if that would work ? Quote Link to comment
datzenmike Posted November 8, 2008 Report Share Posted November 8, 2008 If you mean a 260Z car no it won't fit. Yours is a solid H-190 axle housing his is an independent rear suspension (IRS) with an R-180 differential. Quote Link to comment
Datsunny Posted November 10, 2008 Author Report Share Posted November 10, 2008 well there isnt anything wrong with the stock one i just want to change the gearing so i can go on the freeway i had a guy who offered me 260 parts so i just wanted to check with some guys on the fourm, what do you think would be the best option Quote Link to comment
Datsunny Posted November 10, 2008 Author Report Share Posted November 10, 2008 all i want is to roadtrip in my 521 Quote Link to comment
veryboard Posted November 10, 2008 Report Share Posted November 10, 2008 If you don`t already have one,Put a 5 speed transmission in it.That will help on the highway.Or You could try some 15inch tires on the back.It would be a little harder starting off,but a little faster once you get going(would throw speedo off a bit) Quote Link to comment
datzenmike Posted November 10, 2008 Report Share Posted November 10, 2008 all i want is to roadtrip in my 521 A '70 521 should have 4.375 rear axle with an L16, so it should be able to go lower but take-offs will be slightly sluggish, even more so with a heavy load. The '79 620 with maual tranny had a 4.111 rear end which would work nicely and is not too abrupt a change. The '80-'83.5 2wd 720 Long Bed manual tranny had 4.111 also. The '80-'83.5 2wd 720 King Cab manual tranny had 3.889 Here, read this post on reading the engine tag info to find out what gear ratio is in the 720 truck: http://forum.ratsun.net/showthread.php?t=7521 Quote Link to comment
