720 drive shaft 1985 kc stick shift
S..till T..imeless
  • Replies 4
No. There are two 720 wheelbases, that's the distance between the front and rear wheels. Regular cab short wheelbase and long wheelbase including King Cab.
If there is a noise coming from your driveshaft just replace the three U joints. The driveshafts are balanced assembled so make sure the front and rear are marked so they go back together in the same alignment to prevent vibration.
All you need is a large hammer and a screwdriver to replace them..... http://community.ratsun.net/topic/2329-u-joint-replacement/
