720driver97 Posted June 14, 2017 Report Posted June 14, 2017 I'm looking to swap a vg30e that I found for cheap into my truck, I'm wondering if it will bolt onto my transmission I have now ( have a 4x4 with the z24) I would keep the one with the vg30e but I have toyota mini axles so the front output in the transfer case is on the wrong side. Any help would be greatly appreciated as I have not bought the engine and transmission yet 1 Quote
Lockleaf Posted June 14, 2017 Report Posted June 14, 2017 No it will not bolt to your existing transmission. That being said, you have a divorced transfer case in there right now. Get a 2wd transmission for your vg30, then modify your intermediate drive shaft to fit between the new trans and the stock transfer case. 1 Quote
