NorCalDime Posted October 27, 2008 Report Share Posted October 27, 2008 Anyone done this? I like the twistys, and i have been looking into SCCA stuff, and well i like to drift so cornering g's and nice long sidways slides slosh that oil all over. Has anyone baffled their pan? I was gonna look into doing it, thinking it cant be that hard, just weld in some walls and doors and the like. Anyone have a write up on it? or better yet experience and pics? Quote Link to comment
yellowdatsun Posted October 27, 2008 Report Share Posted October 27, 2008 If your running a stock pan there should never be a need for this. Not sure what you have, but unless it's a hammerhead style pan you shouldn't have a problem with pickup. I even fabbed myself up a hammerhead pan and didn't see any issues with pressure around corners, but I had around 6 quarts in it :-) Making baffles is relatively easy, you can use door hinges and weld then to the upper section, along with making a box in the center for them to swing into. It's a lot of work, so it'd be a waste unless you are having pressure issues though. Quote Link to comment
NorCalDime Posted October 27, 2008 Author Report Share Posted October 27, 2008 Well it is for the KA that i am working on. I heard they are notorious for this so thats why im starting on it early. Quote Link to comment
racerx Posted October 27, 2008 Report Share Posted October 27, 2008 Sounds like a baffling job! Quote Link to comment
