Ricebiker Posted September 2, 2016 Report Share Posted September 2, 2016 I think it's the fuel pump?! It was running strong and then out of nowhere it started slowing down and I could barely keep it running. Sounded fuel starved. It'll start, but I have to keep the pedal to the floor, and then it just barely idles. Fuel pump? 77 Datsun 620 https://goo.gl/photos/nCR9v52Epoc9rap79 https://goo.gl/photos/YRTXxXEMb6v86d4C8 1 Quote Link to comment
datzenmike Posted September 2, 2016 Report Share Posted September 2, 2016 Change the fuel filter. It's likely due for changing anyway even if it doesn't fix the problem. Look on the front of the carb. There is a glass bull's eye. Is the fuel level showing??? If yes you have lots of fuel and it should run. If still running with pedal to the floor likely a blocked jet. 1 Quote Link to comment
Ricebiker Posted September 2, 2016 Author Report Share Posted September 2, 2016 Ok thanks. Carbie cleaning time anyway. Probably never done. I'm the second owner, 104k miles. 1 Quote Link to comment
Ricebiker Posted September 3, 2016 Author Report Share Posted September 3, 2016 Yes! New fuel filter. Definitely fuel behind sight glass, gave it a good spray and seems to be back to normal. Quote Link to comment
