720driver97 Posted January 8, 2016 Report Share Posted January 8, 2016 Dose anyone have a good diagram or picture of the vacuum lines on a z24? Also can I remove the EGR and BPT valve to simplify it, I don't have emmisons tests were I'm from 1 Quote Link to comment
datzenmike Posted January 8, 2016 Report Share Posted January 8, 2016 Yes you can remove them but make a secure block off plate with a gasket or fill manifold holes with JB weld. Remove the SS pipe to the exhaust manifold and screw in a metric pipe plug to fill that hole. If this is really a belief that you will unlock some hidden power let me dissuade you. You can just pull the hose off to deactivate them to test this first. This is a lot of work to simplify it... it's just easier to leave them alone. The EGR and BPT are behind the carb so not really noticeable or in the way where they are. 1 Quote Link to comment
720driver97 Posted January 8, 2016 Author Report Share Posted January 8, 2016 Ok I'll probably let them be, dose anyone have a diagram of the lines? 1 Quote Link to comment
arizonajones Posted January 8, 2016 Report Share Posted January 8, 2016 Should find one in here: http://datsun510.com/manuals/Datsun_Pick-Up_mid-1983_Factory_Service_Manual.pdf 1 Quote Link to comment
720driver97 Posted January 8, 2016 Author Report Share Posted January 8, 2016 Thanks 1 Quote Link to comment
