Motschrocker Posted November 6, 2015 Report Share Posted November 6, 2015 The radiator on my datsun roadster started spraying the other day so i thought it best to just upgrade and get a new aluminum one. My roadster has a l18 swapped into and the old radiator was a custom hack job by the previous owner. He took a stock roadster radiator and drilled new outlets and blanked off the old ones so it lined up with the engine. I bought an aftermarket roadster aluminum radiator so the radiator inlet and outlet are opposite to the motor. So i bought flexible radiator hose to reach. My lower rad hose is quite a bit longer than what stock would be. Will this have any affect on my cooling system? Also the hose is 1 1/2 inch and the inlets are 1 3/8 inch. Will this slight larger hose cause an issue? It is a tight squeeze but i think it will work. Quote Link to comment
Lockleaf Posted November 6, 2015 Report Share Posted November 6, 2015 The extra hose length won't cause you any trouble. The diameter difference might cause a sealing problem. You can try cranking down on a hose clamp, but it's a bit of a gamble. You might be better off getting a hose that fits the radiator and stretching it over the engine side. Heat the hose really good with a blow dryer and should stretch ok. Quote Link to comment
Motschrocker Posted November 6, 2015 Author Report Share Posted November 6, 2015 That was kind of my thought. I can give it a test run and if it gives me any trouble i can try a different hose. Quote Link to comment
