Sign in to follow this
Andy_in_SD
Just Sharing An Old Trick
As I am doing body work, part of this is removing any bondo that folks have slapped on over the decades. I am using an old trick to do this and thought I'ld share. Perhaps everyone knows this one, but if it helps even one person then it's worth sharing.
Instead of drilling, chopping, hammering, chistling and try to force the bondo off the car do this. Get Aircraft Paint Stripper. Soak and old rag in it. Put that over the bondo and cover with plastic like a plastic grocery bag. Tape it in place. Repeat a few times as you work on other stuff.
The aircraft paint stripper soaks into the bondo and makes it rubbery so you can just peel it off, or use a screw driver on it (it falls off pretty easy). This way you are not smacking up the metal around and under the bondo or spending a ton of time fighting it.
Cheers.
Share this post
Link to post
After soaking it, a wire wheel on a drill makes the bondo fly off and leaves your metal unscathed as well. Glad it will help :)
Share this post
Link to post
Good tip.  What most guys don't know is that paint stripper works way better if you only brush it on in one direction.  Not sure why but it says it right on the can and makes a difference in the way that it works.  Cover in plastic also works on houses when stripping for lead paint abatement. Gives everything more time to work before it flashes off all the "Good" stuff that does the stripping.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
