Haseo Posted September 18, 2015 Report Share Posted September 18, 2015 Hello. Im searching for either complete set, or parts of gaskets for my Datsun 140j, 710. It got the L14 engine, however, all the gaskets Im finding is for either L16 and the larger models. Will some of the gaskets fit onto my L14 engine? For example the manifold one? Thanks for any help that any may bring. Quote Link to comment
datzenmike Posted September 18, 2015 Report Share Posted September 18, 2015 L16 gaskets will fit your L14. Only really big difference would be the bore and it might even be the same anyway. An L20B should also work on yours. Better the bore hole on the gasket is too large than too small. 1 Quote Link to comment
datsunaholic Posted September 19, 2015 Report Share Posted September 19, 2015 L13, L14, L16 all had identical 83mm bores. Gaskets are the same. Only difference is the crankshaft and rods. Quote Link to comment
