Bosshog Posted March 12, 2015 Report Share Posted March 12, 2015 PO had wired in push button start, runs great. I hooked up original wiring, runs poorly and dies quickly. It is like it is starving for fuel. Any ideas of where to start? 1 Quote Link to comment
dr.feltersnatch Posted March 12, 2015 Report Share Posted March 12, 2015 it was running good, then you changed something and now it runs like crap. so something you changed is causing your problem. 1 Quote Link to comment
MicroMachinery Posted March 12, 2015 Report Share Posted March 12, 2015 The electrical system should not affect the fuel supply on your pickup(unless someone put an electrical fuel pump on). My guess is that you're losing spark. 1 Quote Link to comment
ggzilla Posted March 12, 2015 Report Share Posted March 12, 2015 Have you tried putting the wiring back to where it ran great? 2 Quote Link to comment
Bosshog Posted March 12, 2015 Author Report Share Posted March 12, 2015 yes, if I put it back it runs fine. I just want it to start off the key like it originally did. It must have developed this problem then PO just wired around it. I thought it was the key switch but replaced it and same problem. 1 Quote Link to comment
Bosshog Posted March 12, 2015 Author Report Share Posted March 12, 2015 Ok, never mind. Just went back and it started. Must have flooded it earlier. Thanks. 1 Quote Link to comment
