datzenmike Posted September 26, 2008 Report Share Posted September 26, 2008 What is the exact width from the axle/drum surface the rim sits against on one side, to the axle /drum surface on the other side. Not the C/L of the wheels or truck width. Yes you can use inches. No this isn't a test, I really don't know and I'm running an '82 720 axle so I can't go out and measure it this w/end. The 720 is 1,430mm or 56.3" and I believe this is wider than the 620. Anyone know? Thanks guys. Yes I used the SEARCH/FAQ, no I didn't get the answer, yes I gave up too easily. Quote Link to comment
