Datsunrider71 Posted December 31, 2014 Report Share Posted December 31, 2014 i recently bought a tachometer for my 71 510 goon and it was missing the needle trim Chrome cover so I got one off of a speedometer but i can't put it on. Can someone tell me how to install it or if the Chrome cover is bigger on the speedometer then the tachometer? Got some picture below Thx Quote Link to comment
shacks510 Posted January 1, 2015 Report Share Posted January 1, 2015 Super glue 1 Quote Link to comment
datzenmike Posted January 1, 2015 Report Share Posted January 1, 2015 First thing I thought of was glue. If it's going to be 'attached' the needle will likely have to com off so it doesn't get damaged. A dab of silicon rtv? Quote Link to comment
KlassicMotion Posted January 1, 2015 Report Share Posted January 1, 2015 Can someone tell him, was it just suppose to clip on originally? Quote Link to comment
datzenmike Posted January 1, 2015 Report Share Posted January 1, 2015 Looks like it has tabs that bend around and hold it on. Quote Link to comment
Datsunrider71 Posted January 1, 2015 Author Report Share Posted January 1, 2015 Happy New Year by the way. If that's the case I will have to take it apart is that hard too do? Quote Link to comment
datzenmike Posted January 1, 2015 Report Share Posted January 1, 2015 If like a clock dial the needle is just pushed on but unlike a clock it's spring loaded to hold the needle at Zero. If you remove the needle there's nothing to stop the axle turning and you may not get it back in the same spot. Then again it may be splined? I would just glue it on. Quote Link to comment
Datsunrider71 Posted January 1, 2015 Author Report Share Posted January 1, 2015 If I gule it it won't effect anythng right? Quote Link to comment
datzenmike Posted January 1, 2015 Report Share Posted January 1, 2015 Just a dab won't. Quote Link to comment
Datsunrider71 Posted January 1, 2015 Author Report Share Posted January 1, 2015 Ok I will do that then I dont what to mess anything up. Super gule will do the trick? Quote Link to comment
datzenmike Posted January 2, 2015 Report Share Posted January 2, 2015 I doubt you will ever want to remove it again and that is a bit permanent. Quote Link to comment
Datsunrider71 Posted January 2, 2015 Author Report Share Posted January 2, 2015 I'm not once I do it I'm never touching again. Quote Link to comment
Datsunrider71 Posted January 2, 2015 Author Report Share Posted January 2, 2015 Good as new Quote Link to comment
datzenmike Posted January 2, 2015 Report Share Posted January 2, 2015 ding ding ding!!!! 1 Quote Link to comment
Datsunrider71 Posted January 2, 2015 Author Report Share Posted January 2, 2015 Now just need to be installed. Quote Link to comment
