PoorMtnKid Posted October 12, 2014 Report Share Posted October 12, 2014 Anyone on here have experience tuning with Nistune and also getting an AEM Uego Wideband connected to the computer. Right now I have all the hardware for it to connect to the computer however when I go to test it to make sure it gets the proper readings as the Widebands manual says I get nothing but 0's. Also I just installed STI yellow injectors and a Z32 maf on my SR20DET, when I go to start the car it fires up but quickly dies out due to excessive fuel. I adjust the injectors and maf in the tune and tried to mess with the latency but got no luck. Any help would be great. Quote Link to comment
rsxse240 Posted October 26, 2014 Report Share Posted October 26, 2014 Do you know what size the injectors are, ie., 270cc, 550cc, etc.? I had problems getting my AEM UEGO to hook up as well. I found that I can only plug it into 2 of the 3 USB ports in my laptop. Also, go into configuration and set up the wideband sensor. I have mine set to "AEM UEGO" "PORT: NONE" and auto search. Quote Link to comment
Burabuda Posted October 26, 2014 Report Share Posted October 26, 2014 hopefully you already know the sti's use a different impedance? Quote Link to comment
jaredperry Posted January 12, 2015 Report Share Posted January 12, 2015 I have a base map if needed. In regards to the WB, I think you have to open the WB software then open up Nistune or vice versa. Also, aren't the STi injectors high impedance? Quote Link to comment
