ITzDarcy Posted September 13, 2014 Report Share Posted September 13, 2014 Hi all I have here a msd boost timing master. The same as the one below.http://www.ebay.com.au/itm/MSD-BOOST-TIMING-MASTER-FOR-USE-WITH-MSD-IGNITION-CONTROL-MSD8762-/191220691545?_trksid=p2054897.l4275 What I wanted to know was .. do I need any other parts or bits to have this retard the boost successfully or can I just install it onto the stock dizzy/coil? Anyone done this before on a Z24? Thanks. Quote Link to comment
datzenmike Posted September 13, 2014 Report Share Posted September 13, 2014 It retards the ignition timing, not the boost. It does say the following: MSD Boost Timing Master for use with MSD Ignition Control MSD8762 Quote Link to comment
