laotsu Posted September 8, 2014 Report Share Posted September 8, 2014 so I am trying to tune and sync my dual Mikuni PHH 44s that I had Wolf Creek Racing rebuild. They are on a Cannon intake. I have been trying to use an Edelbrock Uni-Syn to sync the carbs but I can't get the little bead to rise on any of the horns. I was able to get the motor to idle but it seems like all the gas is going to the front carb. I say this because if I screw in the pilot screws all the way on the rear carb nothing happens to the idle, also when I stall the engine by covering the first horn it is wet with gas afterwards but when I do the same thing on the back carb it remains dry. Is it possible that the front carb is taking all the gas and there's none in the line for the second? on a related note I have driven it but it has NO power and I can barely get over 15 mph in first. Quote Link to comment
datzenmike Posted September 9, 2014 Report Share Posted September 9, 2014 One carb could never use all the fuel available from the fuel pump and leave the other dry. Even more impossible at idle. Float stuck closed or a blockage in the line perhaps. Is there a way to open the other carb and see if there is gas in it?. Quote Link to comment
laotsu Posted September 9, 2014 Author Report Share Posted September 9, 2014 I can take the top cover off. I wouldn't think a float would be stuck fresh out of the box... but anything is possible. now that you mention it there was fuel in the line to carb two when I pulled it to fix a vacuum leak between teh block and intake. Quote Link to comment
laotsu Posted September 9, 2014 Author Report Share Posted September 9, 2014 Thanks Mike. That was it. Wolf Creek sent me a carb with shellac in one of the "L" pipes. Swapped for an old crusty one that came with the Mikunis. It roars and has all sorts of powa now. Quote Link to comment
