Eddie 710 Posted August 10, 2014 Report Share Posted August 10, 2014 I have a nissan sentra with a ka24 with a 5speed i wanna swap into my datsun 710. Let me know if it would work if i had to do a little things or if it would bolt right up? Please help!!?? Quote Link to comment
Eddie 710 Posted August 10, 2014 Author Report Share Posted August 10, 2014 If i make a custom motor mount or something that would work would it be work? Its a ka24de and a 5 speed in a nissan sentra and wanna swap it into my datsun 710 75 Quote Link to comment
Eagle_Adam Posted August 10, 2014 Report Share Posted August 10, 2014 Enough money and time, and sure u got this man Quote Link to comment
datzenmike Posted August 10, 2014 Report Share Posted August 10, 2014 The Sentra didn't have the KA engine and it was FWD also. (are you planning to convert the 710 to FWD???) The closet looking engine was the '91 and up Sentra SR20DE..... it will say what engine was in it on the aluminum tag mounted just above it on the cowl in the engine compartment. We did not get any RWD SR20 engines here. I took this a few years ago. I think a '91 Sentra... This is a FWD engine with the CAS or distributor sticking out of the rear of the head towards the driver's side. If, you could mount this engine in a RWD car, the distributor would not clear the firewall and be somewhere in the car's heater. The FWD SR also has the engine mount locations differently placed than a RWD engine. Quote Link to comment
Eddie 710 Posted August 10, 2014 Author Report Share Posted August 10, 2014 What if i got a rwd distributer? Quote Link to comment
Eddie 710 Posted August 10, 2014 Author Report Share Posted August 10, 2014 And made a custom mount? Quote Link to comment
Eddie 710 Posted August 10, 2014 Author Report Share Posted August 10, 2014 My motor on the sentra i first thought it was a ka but mine looks exactly like that ^^^ must be a sr? Yes i wanna put it in my 710 Quote Link to comment
datzenmike Posted August 10, 2014 Report Share Posted August 10, 2014 You would have to swap an import head on that has the CAS on the front driver's side. I suppose you could rig up a crank fire trigger and eliminate the rear CAS. You would still need a RWD transmission for an SR engine and I'm not so sure the FWD block will fit a RWD SR 5 speed. Maybe someone else knows this. Remember the rear wheel drive SR engine was never imported here on any of our Nissan cars. Quote Link to comment
