logan1600 Posted August 9, 2014 Report Share Posted August 9, 2014 So I've done the timing and have been having a problem getting the cover to seal up I've done it probably 7 times and still leaks coolant I got a new cover and I'm wondering if there's any ceirtan way to tighten the bolts so I don't have to do it again lol and I'm using permatext right stuff. Quote Link to comment
flatcat19 Posted August 10, 2014 Report Share Posted August 10, 2014 Where exactly is it leaking? Did you get all the FIPG off before reinstalling cover? Did you put that little metal gasket on the right side of the cover back in? Is there pitting on the block or cover? Might it be leaking from the pump? Quote Link to comment
Eomund Posted August 10, 2014 Report Share Posted August 10, 2014 Give a pic where it's leaking from. Are you using a new gasket? The sohc, everything should seal pretty easily. Quote Link to comment
logan1600 Posted August 10, 2014 Author Report Share Posted August 10, 2014 I believe its leaking from the right where the water jacket is cause you can hear it pour in to the engine when you start it up. And it has a brand new water pump the first time it happened I though it was the head gasket like a dumbass and $2000 dollars later I had a truck that ran worse than when I took it in. And because they didn't know how to do the timing at the shop so I had to get a new worm gear and oil pump shaft because they put it all on in one piece. But there is no pitting on the block or timing cover should I be titening from the inner bots out? Quote Link to comment
logan1600 Posted August 10, 2014 Author Report Share Posted August 10, 2014 Also I cleaned all the rtv off good and what gasket are you reffering to?? Quote Link to comment
flatcat19 Posted August 10, 2014 Report Share Posted August 10, 2014 No gasket. Just FIPG/silicone. I just did a HG in one of these myself. Glue to told every thing together. On the passenger side, about halfway down on the cover there is a sealing ring/gasket made of metal. I've seen people not use them and be leak-free. Post pics of the cover and motor when you get it back apart. Quote Link to comment
flatcat19 Posted August 10, 2014 Report Share Posted August 10, 2014 When you say right side, do you mean when looking at motor or when sitting in car? When looking at motor-the driver side of the motor is the left. On the right side of the motor there is the whole coolant passage junction in front of the intake. Is any of that causing your leak? You really shouldn't be leaking. It's glue. How can you do that wrong? Quote Link to comment
