logan1600 Posted August 5, 2014 Report Share Posted August 5, 2014 I have a puller and all that good stuff I just can't seem to figure out how to get the Bearing and the thing its pushed on to off of the shaft and fork i don't want to force anything so I figured someone could point me in the right direction. Quote Link to comment
datzenmike Posted August 5, 2014 Report Share Posted August 5, 2014 The release bearing collar, or 'sleeve', or 'housing' is simply clipped lightly to the two ends of the clutch fork. Just grab it by hand and pull forward and off the end of the transmission input shaft. Once off the clutch arm (or fork) the bearing can be removed from the collar with a gear puller. Quote Link to comment
