logan1600 Posted August 1, 2014 Report Share Posted August 1, 2014 I'm changing the head gasket/clutch and flywheel and I noticed pitting on the #4 prison I'm new to building engines and im wondering what would cause this? Quote Link to comment
67_1600 Posted August 2, 2014 Report Share Posted August 2, 2014 Pics would be very helpful. Quote Link to comment
datzenmike Posted August 2, 2014 Report Share Posted August 2, 2014 Detonation or pre ignition. This is the uncontrolled firing of a cylinder before the spark plug does it. Accompanied with severe pressure and temp spikes this is like hitting the upward moving piston with a 16 pound sledgehammer. Caused by too much ignition timing, too low an octane fuel for the compression, cylinder running lean, too high a heat range plug, glowing hot carbon deposits.... FOD or foreign object damage. Piece of spark plug or something down the carburetor got into the cylinder and got tossed around. Head would show even more damage. 1 Quote Link to comment
logan1600 Posted August 2, 2014 Author Report Share Posted August 2, 2014 Very helpful I'm thinking it must be the timing because I messed around with it when I didn't know what I was doing a while back and was running the hell out of it with the timing all jacked up. But why only one piston I Wonder. Quote Link to comment
logan1600 Posted August 2, 2014 Author Report Share Posted August 2, 2014 And I'm new to ratsun and not sure how to post pic's lol Quote Link to comment
datzenmike Posted August 2, 2014 Report Share Posted August 2, 2014 Weakest link in the chain I guess. Maybe runs the hottest at the back. Quote Link to comment
