logan1600 Posted July 13, 2014 Report Share Posted July 13, 2014 I'm doing a simple rebuild of my engine and I have a l20b cam I was just wondering what all do I need to put it in can I use my stock valve parts or do I need the springs, retaniers and lashpads from the l20. Quote Link to comment
datzenmike Posted July 13, 2014 Report Share Posted July 13, 2014 The best thing would be the rocker arms that were used with the L20B and in the order they were on the head. If it's just an L20B cam, then never mind. Inspect the L16 rockers for any wear patterns on the pads. If in good shape they will do. If scuffed or marked I'd replace them. Light scuffs can be sanded out by hand using 800 grit wet sandpaper and a small sheet of glass in the kitchen sink. 1 Quote Link to comment
