FHMan1905 Posted July 12, 2014 Report Share Posted July 12, 2014 Ok needing some help. Which wire leading into to the tail light socket is the brake light wire? Thanks Quote Link to comment
datzenmike Posted July 12, 2014 Report Share Posted July 12, 2014 You should have a $5 test lamp for this. Easier and faster than asking. A factory service (FSM) or even a Haynes manual will also do and is already there for the nest question. The wire from the cab brake lamp switch to the round connector at the back is Yellow/Blue stripe. The wire from the connector to the brake bulbs on both sides is Yellow/Red. Quote Link to comment
