naumanat Posted May 31, 2014 Report Share Posted May 31, 2014 All, I recently rebuilt a Datsun 60 series 5 speed. Everything went together well except one piece - the reverse check sleeve. Which way does the reverse check sleeve go in? Does it get inserted with the retaining C-clip facing up or down? Thanks for the help. The manual does not picture this part well, and I forgot to take a picture of, or label, which direction is up. Andrew Quote Link to comment
ggzilla Posted May 31, 2014 Report Share Posted May 31, 2014 Facing down I think in the RWD 60-series transmission. Facing up in the FWD version. Quote Link to comment
datzenmike Posted May 31, 2014 Report Share Posted May 31, 2014 It can only go in in two positions so try one. When you can't shift directly from 5th into reverse you have it. Quote Link to comment
