DATSUN671 Posted May 20, 2014 Report Share Posted May 20, 2014 Wondering if the l20b valve springs are the same as the napz z24 valve springs? Quote Link to comment
datzenmike Posted May 20, 2014 Report Share Posted May 20, 2014 They are pretty close. The retainers are slightly different but physically the springs are close. The Z series valves are slightly longer so a bit heavier. I was thinking of L series on my Z24 but didn't bother. Quote Link to comment
DATSUN671 Posted May 21, 2014 Author Report Share Posted May 21, 2014 So what ur saying is that I can run a z24 valve spring with the l20b retainer? Quote Link to comment
datzenmike Posted May 21, 2014 Report Share Posted May 21, 2014 Honestly I didn't measure the spring rates on either but they look very close. If at all possible run L springs on an L head, you can't go wrong. If you are out of options I think they will work in a pinch buy keep looking and swap them later. It's actually an easy job not requiring the head to be removed and needing only a length of rope. Quote Link to comment
ggzilla Posted May 21, 2014 Report Share Posted May 21, 2014 Would be a good way to upgrade the Z24 since the L20B springs are better. Quote Link to comment
