difrangia Posted May 14, 2014 Report Share Posted May 14, 2014 I've looked for several hours on several of the different categories on the forum and can't find what I'm looking for. I'd like to find a good straight-on photo of the back of an L-Series engine with the intermediate plate between the engine and trany in place (Flywheel mounted or not, doesn't matter) and/or a straight-on photo into the flywheel housing of an L-Series transmission. I'm looking for the orientation of the starter centerline to the crank/input shaft centerline. Looks to me, in what I've seen, that the starter is something just above on line with the crank centerline (starter 0-5 degrees above crank). Also want to see the bolt pattern of the trany/engine mating. Thanks in advance. Steve Quote Link to comment
