jwerty1 Posted May 3, 2014 Report Share Posted May 3, 2014 So, if I buy a timing kit for an l20b I should have the crank dot at about 3 o'clock and line the bright link with the crank mark and number one on the cam? Quote Link to comment
jwerty1 Posted May 3, 2014 Author Report Share Posted May 3, 2014 And 22 links between them? Quote Link to comment
dr.feltersnatch Posted May 3, 2014 Report Share Posted May 3, 2014 this should help 1 Quote Link to comment
banzai510(hainz) Posted May 3, 2014 Report Share Posted May 3, 2014 use your head Put front cover gently on with crank then ck using the timming marks on from cover. then remove its about 3 330 position but if you got the braike link chain the the head with the dowl up in the 12o clock everyhting will come if . if off move the cam or crank in direction you need to go and it should center itself of put from cover ona dn turn the crank a full rotation the the V should be under the dash on cam tower. Watch vid. its simple. dist should be lined up also Quote Link to comment
