APRILIABILL Posted May 2, 2014 Report Share Posted May 2, 2014 No I'm not a tranny... My kid, as some of you know, talked me into buying a 71/521. It has a 5 speed in it that is a little sloppy, and I'd like to buy some new shift bushings, problem is, not sure which transmission it has in it. It's a 5 speed with the reverse all the way to the left and 1st in the granny position, then 2-5 in an H pattern. Any Ideas??? Quote Link to comment
ggzilla Posted May 2, 2014 Report Share Posted May 2, 2014 1977-1979 Datsun 200SX Quote Link to comment
APRILIABILL Posted May 2, 2014 Author Report Share Posted May 2, 2014 Thanks. Learning, slowly, but surely... Quote Link to comment
banzai510(hainz) Posted May 2, 2014 Report Share Posted May 2, 2014 Chrsyler door hinge kit under the Help brand at O rileys. mine was a multiple bushing kit with 3 sizes I believe Datzenmike should know. I lost my part nuber book http://community.ratsun.net/topic/35578-shifter-bushings/ just use the blank up in the corner enter "shifter bushings" Quote Link to comment
ggzilla Posted May 2, 2014 Report Share Posted May 2, 2014 Shifter bushings are $8 from Nissan. You'll only need the side bushings in most cases the bottom bush is good. Nissan 32855-H1010 Quote Link to comment
APRILIABILL Posted May 3, 2014 Author Report Share Posted May 3, 2014 Well I tore into it this weekend. It may be a 200sx trans, but I'm not sure what this shifter is off. There wasn't any evidence that it ever had bushings or any or help at all, Just a wrong size bolt through it. I was able to amass some great parts and shore every thing up so it feels like new.... Quote Link to comment
cj8281 Posted May 6, 2014 Report Share Posted May 6, 2014 Is the shifter different on this transmission than the regular 4 or 5 speeds? The only shifter I can still find is the one that came out of my '81 720 that was diesel. Quote Link to comment
ggzilla Posted May 6, 2014 Report Share Posted May 6, 2014 The shifters are all different - different lengths, bends, etc But many use the same bushings, at least the little 56 transmission up to the big 71 transmissions. The shifters changed around 1982. Quote Link to comment
