Justinsauter Posted April 19, 2014 Report Share Posted April 19, 2014 So I'm removing the lower ball joints on my 4×4 720 and was wondering if I need to pull the manual hub asembaly get it out? Quote Link to comment
datzenmike Posted April 19, 2014 Report Share Posted April 19, 2014 I don't think so. Unbolt the sway bar on that side, mark and then loosen the adjustment on the torsion bar. This will allow the lower control arm freer movement. Loosen and remove the lower ball joint mounting bolts to the lower control arm and raise slightly. Separate the lower ball joint from the knuckle spindle. 1 Quote Link to comment
Justinsauter Posted April 20, 2014 Author Report Share Posted April 20, 2014 The ball joint is already Loose but the axel is in the way of me sliding it out Quote Link to comment
datzenmike Posted April 20, 2014 Report Share Posted April 20, 2014 The ball joint should move upward from the knuckle joint to remove it, so jack the lower control arm up slightly to give room for the ball joint. Quote Link to comment
