Dean720Ada Posted February 13, 2014 Report Share Posted February 13, 2014 Okay so i just wanted to know or if its possible if you can put a 1998 frontier rear end on the 720. Im sure its the c200. And dont they make a limited slip diff for it. Is the 1998 2wd drive frontier rear end two wide? Or longer in width? Quote Link to comment
datzenmike Posted February 13, 2014 Report Share Posted February 13, 2014 The D-21 is wider than the 720 so very likely the Frontier is even wider. If your 720 is 2wd it will have an H-190, I believe. Only Z24 powered 4x4s got the C-200. I suppose the Frontier 3rd member C-200 (LSD) might swap into the 720. I don't think the gear ratios are all that great though. Quote Link to comment
