GRpufnstuf Posted January 15, 2014 Report Share Posted January 15, 2014 Hey all, I've been reading threads and trying to get my parts together for my new Trans swap. If I've read correctly, AND all my parts are stock I believe I'll be looking at a 200mm 5bolt flywheel when I pull that stuff out. I'd like to upsize to 225 if possible. I'm swapping the rear end to a 3.89 and expect I'll need to be slipping the clutch a little more to get rolling. I think the bigger disc would last longer Is that a possibility? Is there a 5bolt 225mm flywheel? What's a good brand of clutch? On my Volvos I always just use a Sachs, or I've sometimes had Ott's rebuild the friction pads once in a while. I won't have a ton of time for the truck to be down when I get this swap going so I'd like to have all the parts possible on stand by. Thanks Quote Link to comment
datzenmike Posted January 15, 2014 Report Share Posted January 15, 2014 Yes there is a 5 bolt 225mm flywheel. But... It was standard equipment for one year only on the L18 powered, October '73 through August '74 620 trucks. Quote Link to comment
GRpufnstuf Posted January 15, 2014 Author Report Share Posted January 15, 2014 Hmm, so I should invest in a good quality 200mm setup... Quote Link to comment
