72dat-sedan Posted January 9, 2014 Report Share Posted January 9, 2014 I have a 70 510 and I'm doing a ka24de swap. I am using the can am box from icehouse. Can I shorten the harness where you use the wiers from the harness so I can tuck under the dash better. I'm not trying to shorten anywhere else. Just the brown and grey plugs. 1 Quote Link to comment
erichwaslike Posted January 9, 2014 Report Share Posted January 9, 2014 sure. you can shorten any part of it. just dont cut anything that doesnt need to be. 1 Quote Link to comment
Eric Garside Posted January 9, 2014 Report Share Posted January 9, 2014 You can shorten or lengthen any part of a harness. Make sure you use the same gauge wire, preferably the same color/stripe pattern, and I would solder/heat shrink any connections rather than use butt connectors. Quote Link to comment
q-tip Posted January 10, 2014 Report Share Posted January 10, 2014 The ground wires on the ka harness split a fee times so you would have to keep those in mind Quote Link to comment
