twotoedbandit Posted December 29, 2013 Report Share Posted December 29, 2013 My mechanical fuel pump is losing pressure and its time to upgrade to an electric one. While I'm upgrading I thought I would go ahead and run some -an line as the stock lines are also on their way out. Planning on running all the way to the tank. What size lines should I be running? I was thinking -6 but not too sure. I'm running a weber 32/36 on a stock a14 if that helps. Thanks guys! Quote Link to comment
datzenmike Posted December 29, 2013 Report Share Posted December 29, 2013 What makes you think the pressure is dropping? Could it be time for a new fuel filter? Quote Link to comment
twotoedbandit Posted December 29, 2013 Author Report Share Posted December 29, 2013 I can hear pressure leaking out when the engine is off. Replaced both soft lines to the pump and can still hear a hiss. Quote Link to comment
B210GX Posted December 29, 2013 Report Share Posted December 29, 2013 1/2" ID should be good for that monster A14 LOL Seriously though.. Just replace that mechanical fuel pump and call it done... Quote Link to comment
datzenmike Posted December 29, 2013 Report Share Posted December 29, 2013 There is a fuel return line which has a small orifice in it. Once shut off the excess pressure bleeds back into the tank. If your B-210 does it they all do. Quote Link to comment
twotoedbandit Posted December 29, 2013 Author Report Share Posted December 29, 2013 The fuel return is working fine, but I'm still getting a pressure leak from the pump. Anyways, it's getting swapped for an electric pump. So, I'm thinking -6 for the feed line and -4 for the return. Does that make sense? Quote Link to comment
