-an fuel line sizing?
twotoedbandit
My mechanical fuel pump is losing pressure and its time to upgrade to an electric one. While I'm upgrading I thought I would go ahead and run some -an line as the stock lines are also on their way out.  Planning on running all the way to the tank.  What size lines should I be running?  I was thinking -6 but not too sure.  I'm running a weber 32/36 on a stock a14 if that helps.  Thanks guys!
  • Replies 5
