Nikki Carb Level
lilb34n
So i tried turning on a 1967 Datsun 411. It wont start, you can just hear it trying to. I tried putting some Carb Cleaner in it and was able to make the engine turn on for a bit, because it would then shut off when i pressed on the gas or it would just turn off by itself. So i looked into the little glass that the carb has, which says level, which was all the way at the bottom.
Do i have to rebuild the Carburetor? Or what can i do? It also seems to leak from the bottom.
Thank You.
  • Replies 2
Fuel delivery problem. Pull the outlet from the pump and direct into a pail. Crank the motor and you should see strong spurts of gas come out. If not find out why.. maybe a plugged line fro the tank? even more likely a plugged filter?
