HardbodyNaps Posted December 13, 2013 Report Share Posted December 13, 2013 Can anyone tell me if an Intank fuel pump for an 87 Nissan hardbody napz , pushes out to much PSi for 45mm weber side drafts..?! Any input would be greatly appreciated.. Quote Link to comment
ggzilla Posted December 13, 2013 Report Share Posted December 13, 2013 Yes. Webers want 3.5 psi just like most carburetors. Quote Link to comment
datzenmike Posted December 13, 2013 Report Share Posted December 13, 2013 All Z24i motors in the late 720 and early D-21 have throttle body injection and have a high pressure (40-50PSI) fuel pump. Quote Link to comment
HardbodyNaps Posted December 13, 2013 Author Report Share Posted December 13, 2013 So the Intank fuel pump would be to strong to even try and use a fuel pressure regulator on to regulate it to that 3-3.5 correct? Quote Link to comment
datzenmike Posted December 13, 2013 Report Share Posted December 13, 2013 I guess it would work. Might not with a cheap $12 regulator.. Quote Link to comment
HardbodyNaps Posted December 13, 2013 Author Report Share Posted December 13, 2013 If I were to pull the fuel relay to disable the Intank fuel pump and hook up a stock napz fuel pump like they are in the 720's , would that work better?! Quote Link to comment
datzenmike Posted December 13, 2013 Report Share Posted December 13, 2013 The 720 carb electric pump would be around 3.5PSI. As long as it's a carb pump. Some 720s had the Z24i motor with a high pressure pump. Quote Link to comment
HardbodyNaps Posted December 13, 2013 Author Report Share Posted December 13, 2013 What's the Max Psi on the carb style fuel pump for the Nissan Z24? is it 3 psi? Quote Link to comment
datzenmike Posted December 13, 2013 Report Share Posted December 13, 2013 2.7 to 3.4 PSI Quote Link to comment
ggzilla Posted December 13, 2013 Report Share Posted December 13, 2013 Perfect for Weber. Quote Link to comment
HardbodyNaps Posted December 14, 2013 Author Report Share Posted December 14, 2013 At that Psi rate do u think I would still need to regulate it with a FPR?! Quote Link to comment
datzenmike Posted December 14, 2013 Report Share Posted December 14, 2013 At that Psi rate do u think I would still need to regulate it with a FPR?! . Can anyone tell me if an Intank fuel pump for an 87 Nissan hardbody napz , pushes out to much PSi for 45mm weber side drafts..?! Any input would be greatly appreciated.. Yes. Webers want 3.5 psi just like most carburetors. What's the Max Psi on the carb style fuel pump for the Nissan Z24? is it 3 psi? 2.7 to 3.4 PSI Perfect for Weber. Quote Link to comment
