rhd_ole Posted December 12, 2013 Report Share Posted December 12, 2013 OK, so I've had several people give me conflicting answers. I own a '71 Bluebird SSS Coupe. I was told the Bluebird Coupe is shorter/more angled than the US 510 coupes. Is this true? If so that would make the windows, and basically everything above the window line shorter and not compatible with the US version. Reason I'm asking: I have to replace a piece of the stainless window trim and want to be sure I don't' waste my money. Thanks. Quote Link to comment
Tristin Posted December 12, 2013 Report Share Posted December 12, 2013 The only coupes are JDM ones. The 2drs in the US are just 2dr sedans... its a bit confusing, but none of the parts youre looking for will be the same between the models. The top model is a Coupe and the bottom is a 2dr sedan. You can see the heavier slanted roof line of the coupe. 1 Quote Link to comment
rhd_ole Posted December 12, 2013 Author Report Share Posted December 12, 2013 Ahh gotcha, I knew there was a coupe and 2dr sedan, just didn't know they didn't make a coupe in the US.. That was easy enough.. Thanks.. Quote Link to comment
Jesse C. Posted December 13, 2013 Report Share Posted December 13, 2013 Yes, the glass is shorter on the Coupes. Needs different glass, rubber and trim. Quote Link to comment
