Northport Datsun Posted December 6, 2013 Report Share Posted December 6, 2013 I'm trying to assemble my L20B in a 620 Pick Up with a set of twin SU carbs. It's my take on the SSS theme from JDM. Has anyone done this? Does the twin SU Intake Manifold from the A series engine Roadsters fit the L20B head? Does anyone have an intake manifold available? I used Paltech carbs on my 240Z and I am very happy with the performance and reliability of those, so I'm probably going in that direction again. Carbs I can get, but the manifold seems to be harder to come by. Any help is appreciated. 1 Quote Link to comment
Sealik Posted December 6, 2013 Report Share Posted December 6, 2013 Does the twin SU Intake Manifold from the A series engine Roadsters fit the L20B head? Does anyone have an intake manifold available? No........there are some intakes available in the classifieds 220 and K14....the latter is the better of the two Quote Link to comment
ggzilla Posted December 6, 2013 Report Share Posted December 6, 2013 Not JDM, which was EFI. The Datsun 810 SSS with carbs was sold in Europe and Australia. It had two su-style Hitachi carburettors. Quote Link to comment
ggzilla Posted December 6, 2013 Report Share Posted December 6, 2013 Will require L16, L18 or L20B manifold. The other engine types manifold will not bolt on. Quote Link to comment
510SSS Posted December 7, 2013 Report Share Posted December 7, 2013 Why is the K14 Manifold better than the 220? Quote Link to comment
Sealik Posted December 7, 2013 Report Share Posted December 7, 2013 K14 on right....Couple of mins grinding will make it 1.5" to match OE intake gasket Untouched as per pic 220 is about the same size (1.25") as the Lynx on left Quote Link to comment
Sealik Posted December 7, 2013 Report Share Posted December 7, 2013 K14 with purple heartwood transitional isolators...38-46........................................................................ :D Quote Link to comment
ggzilla Posted December 7, 2013 Report Share Posted December 7, 2013 Heartwood isolators ... are you from Canada? Quote Link to comment
Northport Datsun Posted December 7, 2013 Author Report Share Posted December 7, 2013 Excellent information all, thank you very much. Pictures were great too. Quote Link to comment
jvb5577 Posted December 7, 2013 Report Share Posted December 7, 2013 I am with sealik on the K14. People think it is a "smog" intake but in reality the adjuster screw in between the runners help set the idle and better sync the carbs together. I can drop my idle all the way down to 500rpm and have it run smooooooth. Plus as noted above the K14 has larger ports. Look on ebay if you want them now, may pay more but if you want them they are on there. I found my on CL for a great price complete, but waited a while. They are out there though but not as readable available as the carbs. Quote Link to comment
