Syncro Posted November 19, 2013 Report Share Posted November 19, 2013 Alright well I'm working on my sister's 87 Firebird and I keep having fuel delivery issues. The car has a late model 350 efi motor out of my gmc pickup and has been converted to run off a carb. Since there is no where to run a mechanical fuel pump off of I've been using universal pumps, but so far every fuel pump I've had has gone out within hours of use. So recently I installed an intank fuel pump thinking it would be the better direction to go, well the car won't start now. I can hear the pump kick on when the car is turning over. I'm going to have to pull the tank anyway because I believe I forgot to install the fuel strainer before I installed the pump. just as a question would the lack of a fuel strainer keep it from building fuel pressure? I have a fuel regulator installed on the car, a return line going back to the tank, a fuel pressure gauge is hooked up and should work, as it did back when I was use external pumps. The fuel lines seem to have fuel in them but it doesn't seem like the pump is working very well, fuel isn't really flowing up the line to the carb. Any advice would be nice. 7 Quote Link to comment
datzenmike Posted November 19, 2013 Report Share Posted November 19, 2013 EFI pumps are high pressure, like 40+ pounds. Carbs are usually about 1/10th that. Quote Link to comment
Syncro Posted November 19, 2013 Author Report Share Posted November 19, 2013 I've been using low pressure electric pumps made for carbs, they all burn out. Using am airtex intank pump and haven't had much luck, was considering getting the foam baffle crap for this tank, not sure if I'm going to yet. Dropped the tank today and working on putting the strainer in tomorrow and a switch to turn the pump on or off. Quote Link to comment
Komeuppance Posted November 19, 2013 Report Share Posted November 19, 2013 I was just about to say do not use the Airtex junk, and your second post confirms the fail that is Airtex... lol. -Robert Quote Link to comment
Syncro Posted November 19, 2013 Author Report Share Posted November 19, 2013 What would be a good/cheap intank pump? Also realized the return line and feed line were hooked up backwards. Basically need the pump to flow at least 6psi. Need a reliable pump. Quote Link to comment
