DatsunSwag22 Posted October 22, 2013 Report Share Posted October 22, 2013 So I just got a Ka but I'm not sure how the mounts work n drivetrain hook up. And I've heard the wiring is hard also. Any info would work. I have the stock motor I'm taking out n putting in the ka so I kno ther is a Big change. Can someone help me. Quote Link to comment
NissanFam Posted October 22, 2013 Report Share Posted October 22, 2013 Tranny bolts up, wiring can be done multiple ways with the easiest being a can/am box (can be found on this forum), you can use a 720 drivers side mount on the passenger side and a 240sx driver side mount on the drivers side and itll bolt up. If its a 240sx block youll need to convert the oil pan and pickup to a rear sump, if you're using a truck block you'll be fine. Please search before posting. A lot of the information youre looking for has already been discussed multiple times. 1 Quote Link to comment
DatsunSwag22 Posted October 22, 2013 Author Report Share Posted October 22, 2013 I have the 240sx motor. Quote Link to comment
datzenmike Posted October 22, 2013 Report Share Posted October 22, 2013 Tranny bolts up, wiring can be done multiple ways with the easiest being a can/am box (can be found on this forum), you can use a 720 drivers side mount on the passenger side and a 240sx driver side mount on the drivers side and itll bolt up. If its a 240sx block youll need to convert the oil pan and pickup to a rear sump, if you're using a truck block you'll be fine. Please search before posting. A lot of the information youre looking for has already been discussed multiple times. The KA will physically bolt to the 510's 4 speed, hell it will bolt to any L series transmission but it won't work that way. L series and KA motors are mounted about 20 degrees different lean on them. The transmission won't sit properly and the rubber mounts will be twisted and rip out... if you can even get the bolts in. What you really need is a Z or KA series (preferably a stronger KA) transmission with the proper lean to it. Quote Link to comment
Eagle_Adam Posted October 22, 2013 Report Share Posted October 22, 2013 if your asking these questions you havnt searched....... this link will help you http://lmgtfy.com/?q=KA24DE+swap+into+a+datsun+510+-+ratsun.net+ 1 Quote Link to comment
NissanFam Posted October 22, 2013 Report Share Posted October 22, 2013 The KA will physically bolt to the 510's 4 speed, hell it will bolt to any L series transmission but it won't work that way. L series and KA motors are mounted about 20 degrees different lean on them. The transmission won't sit properly and the rubber mounts will be twisted and rip out... if you can even get the bolts in.What you really need is a Z or KA series (preferably a stronger KA) transmission with the proper lean to it. My bad... I was under the impression this question was related to dropping into a 720... disregard the tranny info. Quote Link to comment
DatsunSwag22 Posted October 22, 2013 Author Report Share Posted October 22, 2013 The KA will physically bolt to the 510's 4 speed, hell it will bolt to any L series transmission but it won't work that way. L series and KA motors are mounted about 20 degrees different lean on them. The transmission won't sit properly and the rubber mounts will be twisted and rip out... if you can even get the bolts in.What you really need is a Z or KA series (preferably a stronger KA) transmission with the proper lean to it. I got the ka's tran. Quote Link to comment
DatsunSwag22 Posted October 22, 2013 Author Report Share Posted October 22, 2013 My bad... I was under the impression this question was related to dropping into a 720... disregard the tranny info. Into a 71 510 2door Quote Link to comment
