ericsb210 Posted October 18, 2013 Report Share Posted October 18, 2013 Working with the F10 today, still not running. I opened the oil filler cap to look in while the engine was turning over. The valve I was watching didn't move, thought I had a timing chain problem. Pulled the valve cover off and noticed the push rod to the valve I was watching had came out and was beside the rocker...any ideas on why this would happen? Quote Link to comment
datzenmike Posted October 18, 2013 Report Share Posted October 18, 2013 Engine not maintained. Excessive valve lash. Take the valve cover off and set tdc on that cylinder (valves closed. Install push rod. Set lash on all valves. Quote Link to comment
ericsb210 Posted October 18, 2013 Author Report Share Posted October 18, 2013 Thanks dmike, I will do that! Quote Link to comment
