bmacster Posted September 16, 2013 Report Share Posted September 16, 2013 Howdy, I finally got around to picking up some Honda Passport/Rodeo wheels, which are 16x7. I am curious if some 265/70/16's will fit without any rubbing. Looking at the General Altimax tires, which is on sale right now for a decent steal. Thanks! Quote Link to comment
datzenmike Posted September 16, 2013 Report Share Posted September 16, 2013 On a 720 4x4 29" is considered the largest diameter with light 'rub' on turns and bumps. Your stock height is less that 28" those would be over 30". Not even mentioning the loss of performance from an increase in diameter. A 230/65R16 would be the same the diameter as stock, so speedometer stays accurate and performance unaffected, but they are 1/2" wider. Quote Link to comment
bmacster Posted September 16, 2013 Author Report Share Posted September 16, 2013 On a 720 4x4 29" is considered the largest diameter with light 'rub' on turns and bumps. Your stock height is less that 28" those would be over 30". Not even mentioning the loss of performance from an increase in diameter. A 230/65R16 would be the same the diameter as stock, so speedometer stays accurate and performance unaffected, but they are 1/2" wider. Awesome, thanks Mike! And not to mention cheaper on the pocket book too... Quote Link to comment
